664 to Salzburg, December 2011
pwormald
Kurjač
Kurjač
Prispevkov: 48
Pridružen: 15.02.2009, 16:43
Kraj: Chesterfield
Odgovor Napisal/-a pwormald »
The following is now in final stages of planning by PTG Tours
Train will be Slovenian 664 throughout on 3 SZ compartment carriages
Saturday 10 December 2011
Ljubljana - Jesenice - Salzburg
Sunday 11 December 2011
Salzburg - Attnang-Puchheim - Selzthal - Bischofshofen - Salzburg*
* (likely 664 on rear on last section from Bischofshofen - Salzburg as 664 can only operate short hood leading on ÖBB)
Monday 12 December 2011
Salzburg - Jesenice - Ljubljana
More details on PTG site shortly
http://www.ptg.co.uk
363
Prispevkov: 1420
Pridružen: 06.09.2006, 18:28
Re: 664 to Salzburg, December 2011
Odgovor Napisal/-a 363 »
Nekaj več podrobnosti o potovanju:
http://www.ptg.co.uk/tours/SloveniaChri ... et2011.pdf
Prispevkov: 4017
Odgovor Napisal/-a Tono »
Glede na letak se je Slovenija od Jugoslavije ločila leta 1996...
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
We need more passengers on the train, tickets can be bought here, thanks!
http://www.ptg.co.uk/tours/slovenia_chr ... arkets.htm
Tono napisal/-a:Glede na letak se je Slovenija od Jugoslavije ločila leta 1996...
Namiguješ na tole:
Slovenia is considerably more tranquil and sophisticated than any other destination cast under the "Eastern European" banner, with
almost none of the hang-ups associated with its former Communist connections; 15 years after gently wresting itself from Yugoslavia,
Hja, nekateri res ne ločijo posameznih republik bivše SFRJ. Menda smo letos praznovali 20 let samostojnosti, oktobra bomo praznovali 20 let konca vojne, prihodnje leto pa bodo SŽ lahko praznovale svojih 20 let (kot Slovenske železnice). Če se ne motim, je UIC sredi poletja 1992 določila Sloveniji kodo 79 in od takrat naprej so lahko na tirnih vozilih začelei menjavati znak JŽ za SŽ.
Philip, please correct the leaflet - we are now 20 Years independent and in 1991 the war in Slovenija begun and ended as well, not in 1996!!!
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
Gorchi napisal/-a:
Namiguješ na tole:
I'll inform the writer of this, I just plan the 664 trips :D
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
The timetable is now ready
10 December
E19086 Ljubljana – Salzburg Hbf
Ljubljana 09.20
Jesenice 10.13 – 10.28
Faak am See 11.00 – 11.15 Photostop
Villach Westbf + 11.26 – 11.29
Böckstein 12.47 – 12.57 Photostop
Bad Gastein 13.03 – 14.23 lunch, Photostop
Bad Hofgastein 14.37 – 14.47 Photostop
Schwarzach-St.Veit + 15.08 – 15.10
Salzburg Hbf 16.15
11 December
E14019
Salzburg Hbf 08.33
Attnang-Puchheim 09.30 – 10.20
Aurachkirchen + 10.28 – 10.35
Gmunden 10.42 – 10.51 Photostop
Ebensee + 11.09 – 11.12
Bad Ischl 11.30 – 11.38 Photostop
Obersee 11.57 – 12.03 Photostop
Hallstatt 12.09 – 12.19 Photostop
Obertraun-Dachsteinh.+ 12.24 – 12.30
Stainach-Irdning 13.15 – 13.29
Selzthal 13.47
E14020
Selzthal 14.08
Stainach-Irdning + 14.25 – 14.27
Gröbming + 14.46 – 14.50
Schladming 15.07 – 15.14 Photostop
Radstadt + 15.33 – 15.36
Bischofshofen + 16.02 – 16.19
Salzburg Hbf 17.05
12 December
E14021
Salzburg Hbf 09.05
Hallein + 09.21 – 09.28
Bischofshofen 09.59 – 10.14 Photostop
Schwarzach-St.Veit 10.28 – 10.41 Photostop
Bad Gastein 11.17 – 12.45
Mallnitz-Obervellach 13.02 – 13.16 Photostop
Kolbnitz 13.35 – 13.53 Photostop
Spittal-Millstättersee 14.10 – 14.38 Photostop
Villach Westbf + 15.13 – 15.19
Rosenbach 15.45 – 15.58 Photostop
Jesenice 16.18 - 16.45
Ljubljana 18.20
Prispevkov: 4119
Si bom sposodil kar tole temo, saj je diskusija malo povezana ... če mesto ni pravo, prosim zelene, da prestavijo na boljše mesto.
V temi @363 - foto magazin se je postavilo vprašanje o tem, kako lahko Regan vozi po ÖBB tirih. Imam hipotezo, pa bi prosil znalce, da jo komentirate: morda pa ÖBB tretira vožnjo Regana kot vožnjo muzejca?
Zdi se mi, da naše parne nimajo AS naprav, pa vseeno vozijo po tirih ...
boris
Prispevkov: 293
Pridružen: 10.09.2006, 21:22
Kraj: Obala
Odgovor Napisal/-a boris »
10. decembra so zjutraj prišli OeBBjevi inšpektorji v Ljubljano in kompletno pregledali regana (v izogib zapletom na mejni postaji).
Po temeljitem pregledu so dali "žegen" da lahko vozi...
Prispevkov: 3868
Danes ga tam gori fura tudi naš soforumaš.
Prispevkov: 4119
A strojno osebje je šlo vse skupaj zraven in so na (ali pa blizu) vlaku ves čas ali pa se morda za zamenjavo vsakokrat furajo z vlaki? Koliko posadk pa se pravzaprav rabi? Dve na dan? Več?
boris napisal/-a:Po temeljitem pregledu so dali "žegen" da lahko vozi...
A AS (in ostale varnostne naprave) so kompatibilne z njihovo infrastrukturo?
petindvajsetka
Prispevkov: 853
Pridružen: 28.08.2011, 19:57
mkx napisal/-a: A AS (in ostale varnostne naprave) so kompatibilne z njihovo infrastrukturo?
Varnostna naprava na progi je popolnoma identična, kot pri nas, se pravi imajo točkovni sistem, oziroma balize ob signalih, pa tudi frekvence, ki jih imajo balize so takšne, kot pri nas.
bojan
Prispevkov: 731
Pridružen: 15.01.2006, 19:54
Odgovor Napisal/-a bojan »
LPB
Prispevkov: 4637
bojan napisal/-a:Prve so najzanimivejše :wink:
http://www.fotocommunity.de/pc/pc/mypic ... y/26568293
...in to že kar na novem delu postaje...lepa!
Prispevkov: 3868
igor72 napisal/-a:
... ne ni lepa, temveč super popolna :!:
