Silvo Berdajs grozi ljudem na SŽ
Zaklenjeno
Mičo
Prispevkov: 335
Pridružen: 11.07.2011, 19:00
Odgovor Napisal/-a Mičo »
LukaSLO
Prispevkov: 57
Pridružen: 13.07.2012, 11:59
Re: Silvo Berdajs grozi ljudem na SŽ
Odgovor Napisal/-a LukaSLO »
Očitno na SŽ poteka vojna, kjer se uporabljajo brutalne metode. Verjetno na obeh straneh. Sram jih je lahko!
https://www.24ur.com/novice/slovenija/s ... eznic.html
smok1
Prispevkov: 81
Pridružen: 21.12.2017, 15:56
Odgovor Napisal/-a smok1 »
A ni na tem forumu kar nekaj zaposlenih iz SŽ? Zakaj takšna tišina? :roll:
Prispevkov: 1799
Odgovor Napisal/-a holding »
..."kdor molči, devetim odgovori"...... :mrgreen: ....pravi star slovenski pregovor....
kvak
Prispevkov: 359
Pridružen: 18.07.2009, 16:34
Odgovor Napisal/-a kvak »
strah?
trocken
Prispevkov: 663
Pridružen: 22.12.2009, 10:55
Odgovor Napisal/-a trocken »
kvak napisal/-a:strah?
Strah! Puhne gate!
Southern bear
Prispevkov: 7
Pridružen: 11.03.2018, 14:10
Odgovor Napisal/-a Southern bear »
Is this for real? Do I understand it right - a guy from the labor union at Slovenian railways is threatening with beatings, so employees are afraid to come forward and talk about the issue?
I thought Slovenia was a modern democracy. How is this even possible? Is he going to be prosecuted for his actions?
I am not so good at writing in Slovenian so I will be writing in English. However I urge you to reply in Slovenian, because I understand it (I just can´t write it properly).
smok1
Prispevkov: 81
You understood it correctly. He is threatening that he is going to "fuck them up" (how you interpret that is up to you) if they don't join his side and from what what he is saying it's either his way or the highway.
He is currently "under investigation" and from what history tells us no actual actions will be taken against him. SŽ are one of the last few nests of villainy and corruption in the country, that is why the progress and development at the company is minimal.
mario
Prispevkov: 951
Pridružen: 03.04.2007, 13:13
Kraj: Na pravi strani Alp
Odgovor Napisal/-a mario »
Hahaha, uvdje su se i najhrabriji usrali :D
.... je napis znotraj WCja na ljubljanski železniški postaji ;-)
Southern bear
Prispevkov: 7
smok1 napisal/-a:You understood it correctly. He is threatening that he is going to "fuck them up" (how you interpret that is up to you) if they don't join his side and from what what he is saying it's either his way or the highway.
Thank you for this information. I genuinely can not believe this. Sad.
BTW: you can reply in Slovenian, I understand it, just can not write it (look at my signature).
Zaklenjeno
