AWS
AWS
Odgovor Napisal/-a Nejc »
Kdo ve kaj pomeni ta angleška kratica, AWS? :-k Če bi bilo po nemško bi to bla druga pesem, tko je pa angleško pa ni. Torej, prosim za pomoč! :)
Hvala
Sem našel neki, ampak še vedno ne vem zakaj se gre, ker ne razumem :?
Standard UK style Automatic Warning System (AWS) unit as normally installed between the running rails. These devices are always fitted with a ramp at the approach end to reduce the risk of damage from loose train mounted equipment.
Prispevkov: 4763
"Standard UK style Automatic Warning System (AWS) unit as normally installed between the running rails. These devices are always fitted with a ramp at the approach end to reduce the risk of damage from loose train mounted equipment."
To bi naj bilo:
Standarden UK (Zdr. kraljestvo) AVTOMATSKI OPOZORILNI SISTEM za opozarjanje na slabo pritrjeno vlakovno opremo. Vgrajen med vodilnimi (?)tirnicami inopremljeno z nekakšno "klančino" (ramp)???.
Ljubitelj napisal/-a:"Standard UK style Automatic Warning System (AWS) unit as normally installed between the running rails. These devices are always fitted with a ramp at the approach end to reduce the risk of damage from loose train mounted equipment."
To bi naj bilo:
Ljubitelj hvala za informacijo!! Na hitro se mi zdi, kot pri nas Avtoštop naprava, sam nekam čudna je ta ameriška.
AnejTS
Prispevkov: 1141
Pridružen: 25.10.2005, 18:46
Odgovor Napisal/-a AnejTS »
Evo tukaj pa še opis v angleščini in tudi nekaj slikic kaj bi naj pomenil AWS.
http://www.railway-technical.com/sigtxt7.html#AWS
LP Anej
